Technical Data
Engine Type
| 4 cylinder, with mechanical supercharger.
Capacity, ltrs/cc
| 1.3/1272
Max. output, bhp (DIN)/kw
| 113/83
at rpm
| 6000
Max. torque, lbs ft/Nm
| 111/150
at rpm
| 3600-4400
Compression ratio
| 8.0:1
Bore/stroke, mm
| 75/72
Induction
| Electronic, multi-point injection system (Digifant) with mechanical,
| G-spiral, supercharger and charge air intercooler.
Ignition
| Electronic controlled, mapped ignition.
Exhaust emission control
| Controlled, 3-way catalyst with lambda probe emission to US '83 standard.
Gearbox
| 5 speed
Battery, Amp/Ah
| 175/36
Alternator, max Amps
| 65
Performance:
Top speed, mph/Kph
| 122/196
Acceleration, secs 0-60 mph
| 8.1
Fuel Consumption: Official govt. figs, mpg/ltr per 100 km
Urban cycle
| 31.4/9.0
at constant 56 mph (90 km/h)
| 51.4/ 5.5
at constant 75 mph (120 km/h)
| 37.2/7.6
Fuel grade, unleaded only
| 95 octane (RON) min
Dimensions:
Length, ins/mm
| 146.7/3725
Width, ins/mm
| 62.6/1590
Height, ins/mm
| 52.2/1325
Wheelbase, ins/mm
| 91.9/2335
Track, front, ins/mm
| 52.0/1320
Track, rear, ins/mm
| 53.0/1346
Turning circle, ft/m
| 32.8/10
Front elbow width, ins/mm
| 51.9/1319
Max. luggage capacity ; cu. ft/ltrs (Ball measuring method)
- without rear seat(s) folded
| 10.6/300
- with rear seat(s) folded
| 37.8 1070
Fuel tank capacity, galls/ltrs
| 9.2/42
Running gear:
Wheel size, type
| 5 1/2 J x 13, BBS alloy road wheels; steel spare wheel.
Tyre size
| 175/60R 13H
Brakes, front/rear
| Internally ventilated front discs/self adjusting rear drums.
Steering
| Rack and pinion, with steering damper.
Weights:
Unladen weight, lbs/kgs
| 1830 / 830
Max. gross weight, lbs/kgs
| 2756 / 1250
Trailer load limit, lbs/kgs
braked, 12% incline
| 1433 / 650
unbraked
| 904 / 410
Max tow bar load/roof loading, lbs (kgs)
| 110(50)/110(50)
Engine:
| Water cooled, four cylinder, transversely installed.
| High compression and squish combustion. Blower-type supercharger.
| Light Alloy, cross-flow cylinder head. Long-life spark plugs.
Valve gear:
| Single overhead camshaft; with maintenance-free hydraulic tappets.
Cooling:
| With electrically driven thermostatically controlled fan. Intercooler for charge air cooling.
Electrical System:
| 12 Volt. Low-maintenance battery . Electronic, mapped ignition system.
Transmission:
| Front wheel drive via single plate clutch and all-syncromesh gearbox.
| Five speed sports gearbox.
Chassis:
| Suspension struts at front, track-stable steering, anti-roll bar.
| Torsion beam, trailing arm axle at rear.
| Maintenance-free rack and pinion steering. Safety, collapsible, steering column.
| Diagonally split, circuit braking system. Servo assisted braking. Non asbestos brake linings.
| Internally ventilated disc brakes at front, with self-adjusting drums at rear.
| Load sensitive brake pressure regulator.
